We want to use an AXC F 2152 controller and use the AXL F MA DALI2 1H Dali master module Is there a function block library available for plc next engineer for this module?
Hi beks01, the PLCnEng Library/FB is not available for this module. Please use the process data description for programming/using this module in your application. All available FB libraries can be found at https://www.plcnextstore.com . -Eduard-
