Library release selection
I found out that you add the possibility to choose Programs, FBs, and data types that should be part of the library. But unfortunately, their selection is not allowed.
I just wanted to ask if there is some setting needed or it is not fully functional.
library-release Image library-release hosted in ImgBB With BR
Lukas H.
Hi Lukas, here is the answer from the PLCnext Engineer support team:
_This is planned for the next version 2023.3.__Until then, as a workaround, you have to save a project copy, delete the POUs that you do not want in the library from the project, and then create the library._However, the selection already works for HMI objects and devices.
Thank you very much. I will be looking forward to this feature. I know the workaround.
