Linux SDK Install Problem
I tried to install the 2022.3, 2022.6 and 2023.0 sdks under linux without success.
Can anyone point out what is going wrong?
I used the following commands:
plcncli --version
plcncli 21.0.0 LTS (21.0.0.489)
> sudo plcncli install sdk -d /usr/local/sdk_2022.3/ -p pxc-glibc-x86_64-axcf2152-image-sdk-cortexa9t2hf-neon-axcf2152-toolchain-2022.6.sh
[sudo] password for sofiha:
The format of the file '/home/sofiha/build-system-linux-plcnext/pxc-glibc-x86_64-axcf2152-image-sdk-cortexa9t2hf-neon-axcf2152-toolchain-2022.6.sh' is not supported. Please proceed manually.
-> An exception occured while inspecting the script.
Permission denied
-> Permission denied
> sudo plcncli install sdk -d /usr/local/sdk_2022.6/ -p pxc-glibc-x86_64-axcf2152-image-sdk-cortexa9t2hf-neon-axcf2152-toolchain-2022.6.sh
Permission denied
I tried to update the plcncli to 2022.6
>plcncli --version
plcncli 22.6.0 (22.6.0.1153)
[0%] Install SDK.
An error occurred trying to start process '/home/sofiha/build-system-linux-plcnext/pxc-glibc-x86_64-axcf2152-image-sdk-cortexa9t2hf-neon-axcf2152-toolchain-2022.6.sh' with working directory '/home/sofiha/build-system-linux-plcnext'. Permission denied
-> An error occurred trying to start process '/home/sofiha/build-system-linux-plcnext/pxc-glibc-x86_64-axcf2152-image-sdk-cortexa9t2hf-neon-axcf2152-toolchain-2022.6.sh' with working directory '/home/sofiha/build-system-linux-plcnext'. Permission denied
>sudo plcncli install sdk -d /usr/local/sdk_2022.3/ -p pxc-glibc-x86_64-axcf2152-image-sdk-cortexa9t2hf-neon-axcf2152-toolchain-2022.3.sh
[0%] Install SDK.
The format of the file '/home/sofiha/build-system-linux-plcnext/pxc-glibc-x86_64-axcf2152-image-sdk-cortexa9t2hf-neon-axcf2152-toolchain-2022.3.sh' is not supported. Please proceed manually.
An error occurred trying to start process '/home/sofiha/build-system-linux-plcnext/pxc-glibc-x86_64-axcf2152-image-sdk-cortexa9t2hf-neon-axcf2152-toolchain-2022.3.sh' with working directory '/home/sofiha/build-system-linux-plcnext'. Permission denied
-> An error occurred trying to start process '/home/sofiha/build-system-linux-plcnext/pxc-glibc-x86_64-axcf2152-image-sdk-cortexa9t2hf-neon-axcf2152-toolchain-2022.3.sh' with working directory '/home/sofiha/build-system-linux-plcnext'. Permission denied
Hello svenplc,
please check if you set the permissions (write and execute) for “pxc-glibc-x86_64-axcf2152-image-sdk-cortexa9t2hf-neon-axcf2152-toolchain-2022.6.sh” .
BR Eduard
Thank you for the quick answer. chmod a+x and a+w did fix the problem. Thank you.
