Linux SDK script errors
Hello, I try the following command to install the SDK on my linux (Debian) machine. plcncli/plcncli install sdk -d /opt/pxc/sdk/AXCF2152/2019.0 -p pxc-glibc-i686-axcf2152-image-sdk-cortexa9t2hf-neon-toolchain-2019.0.sh but I am runninge into the following errors The format of the file ‘/home/muddasir/PLCnext /pxc-glibc-i686-axcf2152-image-sdk-cortexa9t2hf-neon-toolchain-2019.0.sh’ is not supported. Please proceed manually.
→ Did not find the expected usage information. The expected information need to include the options ‘-y’ and ‘-d’. Is there something missing from the script. I do not understand why the format of the file is unsupported? With BR Muddasir Shakil
Hello, probably this happens, because you are trying to install an i686 package on an x86_64 system. What is the architecture of your host system? Please download and try to install the pxc-glibc-x86_64 -axcf2152-image-sdk-cortexa9t2hf-neon-toolchain-2019.0.sh. Kind regards, Marcel Luhmann
Hello Muddasir, Firstly - can you please check that you have the correct SDK file? The one you have is for Linux 32-bit systems. If you have a standard Debian installation, then this is likely to be a 64-bit system. Can you please confirm that you are using the correct SDK file? Martin.
Thank you for your replies. Yes, I tried it with the 86_64 bit version as well and I am getting same response. Command: plcncli/plcncli install sdk -p pxc-glibc-x86_64-axcf2152-image-sdk-cortexa9t2hf-neon-toolchain-2019.0.sh -d /opt/pxc/sdk/AXCF2152/2019.0/ I got the same response as you can see in the screenshot. With BR Muddasir
Hello, There seems to be a space in the path - in the "PLCnext " directory name. I think this may be messing up the command. Please try placing the SDK file in a path without spaces. Martin.
Hello Muddasir, please remove the space in your PLCnext folder name and try it again. Capture - Marcel
Hello Muddasir, I just encounter the same problem, I solved this by the comand ‘chmod 777 -R [your sdk package directory]’ ,to change the mode of the sdk files.Maybe u can have a try.
I also have the same problem. I use ubuntu 64x. I tried the 2019 and 2020.3 version and it both had the same errors. I fixed it with: ctbe@ubuntu:~/Documents$ chmod +x pxc-glibc-x86_64-axcf2152-image-sdk-cortexa9t2hf-neon-axcf2152-toolchain-2020.3.sh and after that: ictbe@ubuntu:~/Documents$ sudo extract/plcncli install sdk -p pxc-glibc-x86_64-axcf2152-image-sdk-cortexa9t2hf-neon-axcf2152-toolchain-2020.3.sh -d /opt/pxc/sdk/AXCF2152/2020.3/ Capture
