It looks like I’ve ran into the use case where a customer needs to issue the “shutdown -h now” and/or “poweroff” commands to the controller. It looks as if it is being treated as a reboot command. Is it intended to work this way? Thanks!
Hi Steven, sorry for the delay, we’ve had here in Germany a long weekend. I can confirm the behaviour and will check it asap with the dev and come back to you… Cu Frank
