Login on AXC F 2152 release candidate
Just can not login in a new AXC F 2151 release candidate. With the early adopter version the login was ‘admin’ and ‘admin’. Has this been changed? Also tried the website of the PLC; I get the login page, but further no luck. Kind regards, Wilco
Hi, The password is printed on the body of the release candidate of axcf2152. The username is still admin i thought. Cheers.
Thanks, that worx :wink:
indeed. Should you require root privileges (with the emphashis on should), you may do so by executing:
sudo passwd
You are then asked to provide the password for the root user. From this point on you can login as root with the chosen credential. But again, only do so if you actually require it. Which I think for most usecases isnt the case.
hi,
wath is password for root user
Sorry, user admin is not allowed to execute ‘/sbin/modprobe tun’ as root on axcf2152.
Hello. The answer is on this page of the PLCnext Info Center, in the section “Root rights”:
User rights _PLCnext Controls are supplied with a preset admin user and a default password that is printed on the controller 's housing. This enables access to the most important functions. _
hi,</p>wath is password for root user</p>Sorry, user admin is not allowed to execute ‘/sbin/modprobe tun’ as root on axcf2152.</p>
resolu
