Low and hi byte of word is overturned?
Hello colleagues, please, is it possible that the selection of the upper and lower byte in the word is incorrectly translated?
When I enter .B0, the upper byte is selected. High and low byte of word Thanks, Roman
Hi Roman, If the value in the variable M11_M12_16DI is 16#0001, then this behaviour is correct - 16#01 is the lower-order (least significant) byte. ~ Martin.
From that printscreen it’s not entirely clear, if you have a DO16 card, so try to write 1 in the word .X0 and you will see which bit lights up. .on my card lit up X8.
Hi As far as i remember, the byte order is different in Axioline compared to Inline…
I had some similar experience with the byte order. You can try use the SWAP function on the WORD. - Emil
Thanks, Emil, but why is it different? It’s a little confusing. Roman
Hi Roman, I/O data is mapped in the Motorola format. The result will be so if you mapped all 16 bits to a word. 2020 07 17 09 55 49
Hi Roman, (EDIT: Posted at the same time as Acke, sorry!) The issue here is the “endianness” of the I/O module, which the PLC cannot change. In the data sheet for I/O modules, you should find a statement something like this: 2020 07 17 9 54 20 The Motorola format is big-endian. The architecture of the AXC F 2152 (for example) is little-endian - which is why the bytes are swapped - but you don’t need to know this. To make your code platform-agnostic, so that it can run on either big-endian or little-endian PLCs, you should use the “TO_BIG_ENDIAN” function when writing to Outputs that are mapped in Motorola format, and “FROM_BIG_ENDIAN” when reading inputs that are mapped in Motorola format. Similar for I/O modules that map I/O in Intel (little-endian) format. By using these functions, the I/O will be converted to/from the format of the PLC without you needing to know what that format is. Here is an example from an AXC F 2152: 2020 07 17 9 52 18 Because the AXC F 2152 uses little-endian format, the TO_LITTLE_ENDIAN function does nothing, while the TO_BIG_ENDIAN function swaps the bytes. This behaviour would be reversed on a PLC that uses big-endian format. So, in summary: Check the format that the I/O module supports, and always use the corresponding TO/FROM_*_ENDIAN functions where appropriate. Hope this helps. ~ Martin.
