Matlab-Siulink Library Build Error
Dear Sir, One of Customer is Using Matlab2018a With Target for Simulink v1.42 . Created Simulink Model as per Video but on Build Getting Error Index Exceeds array bounds. Please Suggest Error Details as follows === Model Save (Elapsed: 0.704 sec) ===
=== Model Save (Elapsed: 0.159 sec) ===
=== Build (Elapsed: 29 sec) ===
Starting build procedure for model: New_Model
Warning:Warning: PC WORX Target for Simulink license is not installed
Generating code and artifacts to ‘Model specific’ folder structure
Generating code into build folder: C:\\Users\\Administrator\\New_Model_HLLI
Build procedure for model: ‘New_Model’ aborted due to an error.
Error:One or more Outport blocks of system ‘New_Model’ are either missing or numbered incorrectly. Outport blocks must be numbered consecutively starting with 1
=== Model Save (Elapsed: 0.175 sec) ===
=== Build (Elapsed: 31 sec) ===
Invoking Target Language Compiler on New_Model.rtw
Using System Target File: C:\\Program Files (x86)\\PHOENIX CONTACT\\PC WORX Target for Simulink V1.42\\pxc_hlli\ tw\\pxc_hlli.tlc
Loading TLC function libraries
Initial pass through model to cache user defined code
Caching model source code
Writing header file New_Model_types.h
Writing header file New_Model.h
Writing header file rtwtypes.h
Writing header file multiword_types.h
Writing source file New_Model.cpp
Writing header file New_Model_private.h
Writing header file rtmodel.h
TLC code generation complete.
.### Writing progmeta file New_ModelProgram.progmeta
Writing source file New_ModelProgram.cpp
Writing header file New_ModelProgram.hpp
Writing New_ModelLibrary.meta.cpp-file
Writing .libmeta-file
Writing .compmeta-file
Writing .typemeta-file
Writing .dt-file
Writing source file New_Model_pcworx-hlli.cpp
Writing header file New_Model_pcworx-hlli.h
Writing IEC-61131 HLLI model datatypes
Writing IEC-61131 HLLI common datatypes
Writing IEC-61131 model interface function blocks
.### Writing source file New_Model_pcworx-cosimulation.cpp
Writing header file New_Model_pcworx-cosimulation.h
Writing header file pcworx-ext_svr.h
Writing resource file New_Model_pcworx.rc
Processing Template Makefile: C:\\Program Files (x86)\\PHOENIX CONTACT\\PC WORX Target for Simulink V1.42\\pxc_hlli\\tmfs\\pxc_hlli__next2016a.tmf
Error:Index exceeds array bounds. ---------------------------------------------------------------------------------------------------------------------------------------------- Regards Chetan
Hello, first error message in the log says " Error:One or more Outport blocks of system ‘New_Model’ are either missing or numbered incorrectly. Outport blocks must be numbered consecutively starting with 1". Could you please attach the ModelInfo.txt file from the _HLLI build directory? Greetings
Dear Sir, Please find the files in link below Address: | http://intrans.europe.phoenixcontact.com/transfer/index.jsp?id=467906828&pwd;=gpuUEbo7O3
Regards Chetan
