Memory card
i Wanna use Memory Card for Program Upload and Download Process , Can I Use Memory Card as Program tranfer Tool ?
I want to use any ordinarry Memory Card ( Third party ) Memory Card for program transfer Process Can i use this?
Even i have Found USB C Type Port also available on PLC Next can i use my USB with C type Jack to tranfer Program file from my Pendrive?
[b]In theory[/b] this may be possible, since at the end of the day the project "send" process copies files to the upper directory of the overlay file system, and if an external SD card is inserted at the time then this upper directory is on the SD card. If the same files were copied to the same SD card when it is inserted in a Linux PC, then when the SD card is inserted back into the PLC the project should be updated.
One problem with this idea is that there is no public documentation describing exactly what files from a PLCnext Engineer project are copied to the PLC. So this process would not be supported by Phoenix Contact.
[quote="harshid"]I want to use any ordinarry Memory Card ( Third party ) Memory Card for program transfer Process Can i use this?[/quote]
The use of third-party memory cards is not supported by Phoenix Contact.
[quote="harshid"]can i use my USB with C type Jack to tranfer Program file from my Pendrive?[/quote]
No, unfortunately the USB port on the AXC F x152 PLCs has no function at the moment.
Ok Noted.
Thanks for Your Valuable Response on this.
