I am setting up a communication system with multimeters for electrical quantities using 10 AXL F BK PN TPS with AXC F 2152, modbus RTU will be used to communicate with the multimeters.
Which function blocks should I use to read multimeters through the AXL F BK PN TPS?
Can you show an example?
Grateful for the attention,
there is a library available in the plcnextstore which you can use PLCnext Store | Modbus_RTU. Programming examples are included in the download. For the serial communication you need a serial communication module attached to the AXL F BK PN TPS, e.g. AXL F RS UNI 1H or AXL SE RS485.
