Modbus_TCP_15 with 2025.0LTS
Dear all,
Since sometime PLCnext Engineer 2025.0 is out and since 2024.x is no longer available on the website I thought I will try 2025.0LTS.
We’re using the Modbus_TCP_XX library with it latest installment (15 as of today). In the change log something is mentioned about incomparability and (“proven”) workaround. As follow:
“The function blocks UDP_SEND, UDP_RECEIVE,
UDP_SOCKET, TLS_SEND_2, TLS_RECEIVE_2,
TLS_SOCKET_2, GET_EXCEPTION_INFOS, PACK
and UNPACK can now be found in the library
PLCnext Controller. For projects that use these function
blocks that means that a reference to
PLCnext Controller needs to be added. When the function
blocks are used in a library then the root project
needs to be extended by the reference to
PLCnext Controller and released as a library anew.”
Before adding the PLCnext Controller Library I had the message, “TLS_SOCKET_2” is not a valid function block" (and more). After adding PLCnext Controller Library I have now “The Specified IEC type ‘TLS_SOCKET_2’ is inaccessible” (and more).
Can I get some help with this? Fixing the issue?
Thanks in advance!
Hi! it seems that developers have to release new version of library to support new ide.
BR
and since 2024.x is no longer available on the websiteAll previous versions of softeware are still available.
There are in the other section of “Download” panel:
From “known errors and limitations” in the 2025.0 LTS Release Notes:
Thank you . I also received an email from Dutch Customer Support stating that the issue about the incompatibility is noticed and send over to HQ.
Thanks for stating. Maybe there was a workaround to modify an user defined library so that we could go on with our work.
But my suspicion has been confirmed, and I just have to wait for Modbus_TCP_16.
Thanks to all of you =)
