Modbus_TCP library issues with datatype after conversion to PLCnext Engineer 2023
I have really big problem after I coverted the project to 2023 LTS versions. The Modbus_TCP library from the store is returning the error INT is not equal to UDINT. Unfortunately, this is inside some of the blocks of the Library. https://www.plcnextstore.com/eu/app/1443image.pngI could go back to back-up to version 2022.6 LTS but I am working on multiple projects that I export to my own libraries and I done some changes to multiple projects after I transitioned to 2023 so it would be a real pain to reflect all the new things to back-up version.
Is there a possibility of hotfix the library?
BR
Lukas H.
Have you checked with the library developers?
They can be contacted using the “Contact” button on the library product page in the PLCnext Store.
I just did.
Hopefully, they will read it. :slight_smile:
Thank you
Hi Martin,
I would like you to ask if there is possibility save 2023 project as version 2022?
I guess there is not such option but I want to be sure.
Thank you
No, you would need to use two versions of PLCnext Engineer, but one project cannot be used in two different versions of PLCnext Engineer.
A new version of the Modbus TCP library has now been released, which should fix that issue.
