More than 1 XT ETH 1TX
Hi to everyone!, i am looking to connect to at least 3 different networks with an 2152, is it possible to use more than 1 XT ETH expansion module ? Would Node-Red ahave any problem working with the 3 different Networks?
Thnks!
Hello Manuel,
you can connect one extension module to the left of the AXC F 2152. I would like to recommend to use the AXCF3152 Controller with 3 ETH-Interfaces.
Q: Would Node-Red ahave any problem working with the 3 different Networks?
A: Unfortunately, I’m not familiar with Node-Red. But take a look at the Node-Red homepage. There is also a forum there. Maybe someone there can help you.
BR Eduard
Thanks for the quick reply!, i will look into it.
Kind Regards
