Move code from one PLCnext Engineer project to another
Good morning,
In case there are more than one programmer
working in a PLCnext Engineer project at the same time (each with one copy of
the project), is there any easy way to move the developed code (for example
local Functions, Function Blocks or Programs) from one project to another?
Right now I’m copying a function block and
the only way I found to do it is to create manually the function block in the
end project, define one by one all it’s variables and copy de code. I hope
there is a better way to do it.
Can anyone help me please?
Hi BeePlaneter_1,
in newer PLC next Engineer versions there is SVN/Git support but you need a license for it.
Another option is to use File->Import from another project.
Cheers
DivisionByZero
