MSG_GEN0025 error code
Hi everyone,
I am trying to debug a programm but it if not possible and the error code that appear is “MSG_GEN0025”. What does thar error means? There is any list of error codes? Also appears the error “MSG_ONL0048”
Thank you
Hello Everyone,
Is this problem fixed?
This was the reply to the original to the original question, that unfortunately was not posted here:
MSG_GEN0025 says that the build failed. There must be additional error messages in the error list of the cross functions area.MSG_GEN0048 is subsequent error that says that online mode is not possible because the build failed. ?name=image.png
Thank you for the fast response Martin!
I can’t manage to find the right forum for the fix.
Would you mind redirecting me there?
The reply to Rookie’s original question was posted internally here at Phoenix Contact by the PLCnext Engineer support team, but unfortunately that answer was not posted in this public forum. The answer I’ve posted above is all the information that I found. If there are additional questions, please let us know.
