Martin, FindTiff.cmake is under the cmake directory . I did save the FindTiff.cmake file, however getting the same error. CMakeLists.txt – cmake_minimum_required(VERSION 3.10)
project(runtime)
if(NOT CMAKE_BUILD_TYPE)
set(CMAKE_BUILD_TYPE Release)
endif()
################# create target #######################################################
set (WILDCARD_SOURCE *.cpp)
set (WILDCARD_HEADER *.h *.hpp *.hxx)
file(GLOB_RECURSE Headers src/${WILDCARD_HEADER})
file(GLOB_RECURSE Sources src/${WILDCARD_SOURCE})
add_executable(runtime ${Headers} ${Sources})
################# project include-paths ###############################################
target_include_directories(runtime
PUBLIC
$CURRENT_SOURCE_DIR}/src>)
################# include arp cmake module path #######################################
list(INSERT CMAKE_MODULE_PATH 0 “${ARP_TOOLCHAIN_CMAKE_MODULE_PATH}”)
list(APPEND CMAKE_MODULE_PATH “${PROJECT_SOURCE_DIR}/cmake”)
################# set link options ####################################################
WARNING: Without --no-undefined the linker will not check, whether all necessary
libraries are linked. When a library which is necessary is not linked,
the firmware will crash and there will be NO indication why it crashed.
target_link_options(runtime PRIVATE LINKER:–no-undefined)
################# add link targets ####################################################
find_package(ArpDevice REQUIRED)
find_package(ArpProgramming REQUIRED)
find_package(TIFF REQUIRED)
#find_package(NE10 REQUIRED)
#target_link_libraries(runtime PRIVATE ArpDevice ArpProgramming NE10::NE10)
target_link_libraries(runtime PRIVATE ArpDevice ArpProgramming LIBTIFF)
################# install ############################################################
string(REGEX REPLACE “^.\\\\(([0-9]+\\.[0-9]+\\.[0-9]+\\.[0-9]+).$” “\\\\1” ARP_SHORT_DEVICE_VERSION ${ARP_DEVICE_VERSION})
install(TARGETS runtime
LIBRARY DESTINATION ${ARP_DEVICE}${ARP_SHORT_DEVICE_VERSION}/$/lib
ARCHIVE DESTINATION ${ARP_DEVICE}${ARP_SHORT_DEVICE_VERSION}/$/lib
RUNTIME DESTINATION ${ARP_DEVICE}${_ARP_SHORT_DEVICE_VERSION}/$/bin)
unset(_ARP_SHORT_DEVICE_VERSION)
