.net Core, direclty access IO Module Pins
Hello, I installed .net core on the PLCNext F 2152. Works as expected so far. But: Is there a possibility to access the Axioline F DI8/1 DO8/1 module ports directly from within .net Core (as I would do it on a Raspberry PI) I know I can access the IO Pins going through OPC Variables into the PLC system with PLCNext Engineer. But I do not want to use any of the build in PLC functionality, since I need to write the IO Ports really fast (20MHz). Please let me know if this question is unclear. Thanks for your help. Best Regards, Richard
