No DataLogger Editor
Hey, according to the online help I should see a new Editor for the Datalogger if I run PLCNE version 2020.6 (firmware on the controller is the latest too), but there’s nothing new. Do I need a SD-Card inside my controller for this? The project currently opened was created with 2019.x but I doubt that this is the reason. kind regards, frank
Hello Frank,
thanks for the hint we will update the documentation accordingly. you will need to replace your PLC with a updated PLC template 2020.6.
Create a backup of your project
(On the righthand side search for the PLC 2020.6 and Copy it. Then on the lefthand side replace the existing plc) kind regards Oliver
thanks for your hint, that helped. kind regards, frank
