I have tried to install start the Node-RED for PLCnext x86 4.0.5.2 PLCNext app on my AXC F 3152 controller (Hardware version 04, Firmware: axcf3152-2025.6.0-25.6.0.40) but I get the following message:
Failed to start PLCnext Technology App ‘NodeRED for PLCnext’. Error code: OciContainerPartError
Do you have any idea what is the problem?
Thanks in advance,
Gábor
Downgraded the firmware to Firmware version 2025.0.3 (25.0.3.103), same problem
The version history on that app is a bit confusing (to me, at least):
If you contact the app developers using the “Contact Developer” button on the app page in the PLCnext Store, they should be able to tell you if you have the correct version, and then help to install the app.
