Node red update problem
I have an EPC1522. When I try to update or install nodes in node-red with the palette manager, I always get a checksum error. How can this be solved?
At the momente node-red palette inside EPC is disfunctional and will be fixed soon, you can in any case installa manually: 1. Connect to your EPC via “Putty/SSH” and log in with admin credentials and type in following commands: 2. export PATH=/opt/plcnext/edge/nodejs/bin/:$Path [You only need this command once!!!] 3. cd /opt/plcnext/edge/nodejs/lib 4. npm install NAME_OF_PACKAGE 5. After the installation of the packages are done, you have to restart the device. Those nodes should be visible in Node-RED now. We did it multiple time and it works! Regards
