Nodered does not start after offline installation?
Hello, I have just installed in offline mode the Nodered App and restarted the AXC 2152. After that I set the app in running state from the Web with the Start Botton. It seems to be running, but I can not get into the dashboard when I enter :1880 in the web browser. Should I configure anything else? Thanks Angel
Hi Angel, It looks like you have installed the Node.js app … but there are several more steps required to install Node-Red, which is a package that runs on the Node.js framework. The procedure that seems to work for most people is described by Dan Moeller, here: https://www.plcnext-community.net/en/discussions-2-offcanvas/opc-ua-connection-with-nodered-client-not-posible-with-fw-2019-3.html#reply-1957 … however since the AXC F 2152 now supports OCI containers, the Node-Red gurus in the Community are recommending containerised solutions as an alternative. See the two most recent articles in the Makers Blog, here: https://www.plcnext-community.net/en/hn-makers-blog.html Hope this helps. ~ Martin.
Hola Angel, I agree with Martin. Please try to install Balena Engine and then the node-red image on the controller. This is very easy, the installation is very fast and you have the latest version of node.js and node-red. The node.js app from the store has not been updated for quite some time. Just have a look in the last two posts on the makers blog.
Hola Stefan, Martin, @Martin, yes you are right I have realized I’ve still not installed Nodered but Nodejs. @Stefan, I’m going to try, first time with containers… lets see! :O) Thanks
