NTP Server - SNMP Libraries
hi all, I need to use an ntp server, with GPS to get the position, the data is transmitted via SNMP protocol.
I used the library downloaded from the SNMP plcnext store, but after parameterizing and running the setup, I keep getting this error:
"The specified IEC type 'IPC_UDT_IP_SOCKET' is inaccessible."
I try to do every thing, like  to change type of variable, o create a new variable. but nothing work.
How can i do to resolve it?
[SNMP_BLOCK_error.PNG](https:\\/\\/forum.plcnext-community.net\\/uploads\\/HIOBTL5D59AO\\/snmp-block-error-png.png)
I solved the problem,
there was a problem in moving the user library FB from the current project to a user library after inserting a call of the project FB.
So it's only necessary reinstall libraries ALL in the same default folder.  Simply.
Best regards. Antonio.
