NTP Set up
Hello, I’m trying to connect the AXC 2152 (2020.3 FW and 2020.3 Template) over NTP with a NTP Server on the internet. The Change Notes referred template 2020.3.1 is not available in 2020.3 PLCnE. 2020 05 04 17 39 46 PLCnext Engineer C Users Public Documents PLCnext Engineer Projects PSN 29042 In point 2.16.2.1 from the 2020 LTS Manual is described how to set up the client configuring the /etc/ntp.conf file. 2020 05 04 17 51 31 OpenSSH SSH client This file does not contain the configured server on the PLCnE. I don´t know how to proceed in order to set it up. Any sugesstions? Thanks, Angel
Moved to PLCnext Engineer category. (Internal reference no. 00130110).
Hi Angel, This looks like it might be a bug. It is being investigated and, if it is a bug, it should be fixed in version 2020.6. There are two possible work-arounds at present:
                                               1. In PLCnext Engineer, use IP addresses instead of DNS names for the NTP server address(es).
                                               2. Edit the `ntp.conf` file directly on the PLC.
Sorry for the inconvenience. ~ Martin.
Ok Martin. I can wait. Thanks.
Update: This has been fixed in version 2020.6.
