Сonnection to "AXC F 2152/A-SAMPLE"
Hello. I’m trying to connect from “PLCnext Engineer 2019.9” to PLC “AXC F 2152/A-SAMPLE”.
When I create a project, I can’t find my Controller among the “COMPONENTS” in the right window.
I also can’t find the PLC “AXC F 2152/A-SAMPLE” description file (*.xml) to import into the “PLCnext Engineer 2019.9” environment.
When I choose type PLC “AXC F 2152”, I get a warning: "Type does not match! project: “AXC F 2152” online: “AXC F 2152/A-SAMPLE”. In what way and in what environment I can connect to the PLC “AXC F 2152/A-SAMPLE”?
Hello, That hardware was a sample provided as part of the PLCnext “early adopter” program, which concluded some time ago, and is no longer supported. Please get in touch with the Phoenix Contact representative who provided you with that sample, and they should be able to help you get a production version of that PLC. - Martin
report.txt
