OPC UA connection with certificates
Hello, I am trying to connect to the AXC F 2152 OPC UA server using certificates. I would like to use my own certificates for this. In this forum I have found several articles how to achieve this but they seem to be outdated. Is there a document giving step by step instructions which certificates in what format are needed and how to put them on the PLC via WBM? Any help would be kindly appreciated.
Hi Stefan, I guess the Certificate Authentication chapter in our PLCnext Infocenter should help you out. Take care Frank
Hi Frank, thank you for your reply. This helps just a little as there is no information about the certificates themselves. Is there any information about the format in which the certificates have to be created and stored?
Are there any updates on this topic? I would really appreciate a quick answer to my question.
I have asked for additional information on this topic to be added to the Info Center. ~ Martin.
This old Makers Blog article article has now been updated and re-published - hopefully this answers most questions on this topic. https://www.plcnext-community.net/en/hn-makers-blog/283-how-to-use-your-own-security-certificate-with-an-opc-ua-server.html ~ Martin.
