OPC UA server namespace
Hello, is there any possibility to set the namespaces of the new models created on UAModeler?
Otherwise they can change by uploading the new model each time.
Untitled Image
I can’t see an easy way to specify this in UaModeler. Perhaps someone at Unified Automation knows if/how this can be done.
Regardless, from my reading of the documentation, changes in the namespace index should not be a problem for well-written OPC UA clients:
image.png(from „OPC UA NodeId Concepts“ on the Unified Automation website)
Thank you very much Martin. Your advice is helpful. :slight_smile:
