Opencv + ffmpeg
Hello, Could you upload opencv + ffmpeg library and ffmpeg user-application for PLCNext 2152? I built both library based on the tutorial, instruction and simple application works, but ipcam application didn’t work with the libraries. When I tried with ffmpeg user-application(“ffmpeg -i …”), the application didn’t work because interpreter setting inside of the app was not correct. Best regards, Atsushi
Hello Atsushi,
what exactly is the problem you are facing right now?
So you sucessfully build a demo application with OpenCV and FFMPeg?
I used to capture pictures from an AXIS IP Cam. cv::VideoCapture(WebcamUrl);
You can quick fix the Interpretersetting for the FFMPEG binary like this:
ln -s /lib/ld-linux-armhf.so.3 /lib/ld-linux.so.3
Or directly during configure time of FFMPEG with the LD flags I think.
kind regards,
Hello Oliver-san, Thank you for the information. Now the ffmpeg application got to work by the symlink. However, VideoCapture() didn’t work(error returned “isOpened()”). Should I care about any version combination between opencv and ffmpeg? I’m using opencv 3.4.0 and ffmpeg 4.0.5. Best regards, Atsushi
Hello Atsushi, I need more code snippets and complete error messages to support you.
I am not aware of not working Version combinations but maybe you ca direct this question directly to the publisher of openCV and FFMpeg kind regards,
