Hello, I use the AXL F IF CAN 1H 2702668 for a CANbus communication. i want just establish a communication via PDOs but i don’t found where we write the node ID of slave and establish a liaison in “physical Topology” like profinet? How we do to incorporate the slave in PLCnext, because the EDS file is not possible? Thank’s.
Hello, There is a function block library + documentation in the PLCnext Store which may help: https://www.plcnextstore.com/#/189 Please let us know if this provides the answer, or not. ~ Martin.
can’t find https://www.plcnextstore.com/#/189 on the store.
What function block is it?
We want to make something like a CAN Gateway.
We have PLC that control frequency inverter, which is out of production.
The PLC project is locked.
We want to use AXL F IF CAN 1H as a slave instead of freaquency inverter, to handle PLC CAN command and control frequency inverter from AXC.
Have any idea on implementing this?
Canbus library. We use it to control inverter from AXC, but what if we need to use PLC as CAN slave device?
