PC WORX Target for simulink
I am having trouble building/compiling a simulink model using the PC WORX target for simulink. I have Matlab simulink version R2020b with coder installed. And I have also installed the SDK for AXCf2152.
When I click on Build button on simulink I get this error:
_The call to pxc_hlli_make_rtw_hook, during the entry hook generated the following error:_Property ‚HLLI_SDK_lastName‘ does not exist
_The build process will terminate as a result._Caused by:
* _Property ‚HLLI_SDK_lastName‘ does not exist _
Please try using the PLCnext Target for Simulink.
I installed „PLCnext Target for Simulink“ and tried to build my model and this time i get this error:
„_Error:The call to pxc_plcn_make_rtw_hook, during the entry hook generated the following error:__block_diagram does not have a parameter named ‚PLCN_ExceptionHandling‘___The build process will terminate as a result.__Caused by:__block_diagram does not have a parameter named ‚PLCN_ExceptionHandling‘
