PcWorx Enginner activation
I’ve got theTicket-ID from Application Support SD by email and I´m trying to follow the online activation instructions. However the procedure is not working properly. At Phoenix Contact Activation Wizard the option “Activate License” is not available. 1. I have connection to Internet 2. My CodeMeter Container are running 3. The Firewall are desactived
Hello Ricardo, sorry for the delay. Is this still an issue? Did maybe the WindowsFirewall got enabled when you deactivated your firewall? What is your Operatingsystem? Are you using a Virtual Machine or a host PC?
Wich activation Wizard version do you have? can you Ping google from CMD?
Maybe some Proxysettings you need are not systemwide but only in the Browser? Internal PC Worx Engineer License (internal) https://plcnext-community.net/index.php?option=com_fss&view;=faq&catid;=6&Itemid;=272⟨=en
Hello Oliver The problem still persists. Please see below the answers in bold Did maybe the WindowsFirewall got enabled when you deactivated your firewall? The Firewall are disabled What is your Operating system? Windows 7 (64 BITs) Are you using a Virtual Machine or a host PC? The software are installed on my host PC Wich activation Wizard version do you have? Phoenix Contact Activation Wizard (Build 1.0.80.0) can you Ping google from CMD? Yes, I dont have any problem to ping Google or another website Maybe some Proxy settings you need are not system wide but only in the Browser? You recommend to disable the proxy settings ?
Hello Ricardo, thats why I asked for a ping from CMD…
sometimes people use Proxy settings inside the Browser and can reach everything fine but all other programs that do not have those settings wont get a connection…
But if you can reach it from CMD it should be fine…
Does the FAQ section help you?
There is an additional area now: Licnence Management.
There you can find some information how to get the Offline registration running (you need some PC maybe outside of company network) that is able to reach the Activation server.
