I have made a complete reinstall of my AXC F 2152, starting from factory default. Then, FW 2019.3, then node.js from the PlcNetx store, and then, node-red. Then, I install ping node from the node-red palette. Here is the result : 2019-05-15T09:57:17.180Z Install : node-red-node-ping 0.0.16 2019-05-15T09:56:50.124Z npm install --no-audit --no-update-notifier --save --save-prefix=“~” --production node-red-node-ping@0.0.16
2019-05-15T09:57:25.541Z [out] + node-red-node-ping@0.0.16
2019-05-15T09:57:25.541Z [out] added 1 package from 1 contributor in 14.572s
2019-05-15T09:57:26.244Z rc=0 So then, as the result code is correct, I think the node will work correctly. So, I create a simple ping node connected to a debug node : [{“id”:“dcb4bee1.e30e1”,“type”:“debug”,“z”:“c71d23e6.4d3ab”,“name”:“”,“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“payload”,“targetType”:“msg”,“x”:611.53125,“y”:301.9375,“wires”:},{“id”:“ea125913.57d348”,“type”:“ping”,“z”:“c71d23e6.4d3ab”,“name”:“”,“host”:“www.google.com”,“timer”:“5”,“x”:407.7890625,“y”:304.7734375,“wires”:[[“dcb4bee1.e30e1”]]}] And I get this reply in the debug node : 15/05/2019 à 12:03:35node: ea125913.57d348 __msg : string[29] “ENOENT ping command not found” Of course, when I use a ping in the console, it succeeded : admin@axcf2152:~$ ping www.google.com
PING www.google.com (172.217.22.132): 56 data bytes
64 bytes from 172.217.22.132: seq=0 ttl=47 time=15.803 ms
64 bytes from 172.217.22.132: seq=1 ttl=47 time=14.257 ms
64 bytes from 172.217.22.132: seq=2 ttl=47 time=13.349 ms I really don’t understand why that fails, and waht i can do. I tested the same thing with an exec node, making a ping, and i have the same result. An advice? Thanks
