HI, I am getting the following error while trying to install the SDK for C++ programming. I have already installed the PLCnCLI 2020.0. Please provide a solution.
I had the same problem a few weeks ago. After I deleted the plcncli folder in AppData/local (see image above), I was able to re-install the plcncli.
FYI, this problem has been recorded and discussed here: "The application to execute does not exist" · Issue #4 · PLCnext/PLCnext_CLI_VS · GitHub
