dear developer, Since the update of plcnext engineer → 2021.6 The libraries from eclypse c++ get updated only once after starting plcnext-engineer. Once updated the link seems to be released and nothing is automaticaly updated. If I build the project in eclipse normaly plcnext-engineer detects a change, this does happen only once. in order to get the latest change from a second or third etc. change I have to restart plcnext-engineer or clean the project. is this some setting that needs change? hope you guys have a fix. sincere Nick
I have reproduced this problem (and the correct behaviour in earlier versions) and passed this information to the Product Manager. I will post here when there is an update available.
I have seen the same behavior for the C# and visual studio function blocks. /Stefan
This now appears to be a bug in PLCnext Engineer 2021.6. If this is confirmed, then I expect a fix will appear in an upcoming version.
