Hi To day i have made a change in the plc program and downloaded the complete program to the controller. Then the HMI started to make some strange faults about the OPC Tags.
I restarted the HMI many times but still the same.
Then i looked at the plc, and find all my program code is stopped. All FOR loops was “0” in debug mode.
Even ladder lines with True as contact, and some outputs as coils was off?
No reaction on force/change of variables from PLCnext Engineer…
I tryed to download the program again with no difference. Both complete and changes, with the same result. I tried power off, and on serval times and same result?
I tried reboot from PLCnext Engineer, and same result.
Then i did a reboot to factory default. then i was able to download the program (must set IP again and so on)
Now it’s working again? Has anybody tried something like this biehavure ?After this the WBM is a little strange about the IP adress: i don’t know why, the controller has never been other adresses than 192.168.1.10 and 192.168.11.11…
