Plcncli new project not posible
Hello, I can not create a Project with the plcnli function (see attached picture) What I did after that:
                                               1. remove the SDK with: plcncli.exe set settings SdkPaths -r C:\\\SDKs\\\AXCF2152\\\2019.0
                                               2. delete the C:\\\SDKs\\\AXCF2152\\\2019.0 folder
                                               3. install the plcncli again with: plcncli.exe install sdk -p c:\\\pxc-glibc-x86_64-axcf2152-image-mingw-cortexa9t2hf-neon-toolchain-2019.3.tar.xz -d C:\\\SDKs\\\AXCF2152\\\2019.
But I have the same result PLCnCLI version: plcncli 2019.0 LTS (19.0.1.769) Thanks Angel
Hi, I think the failure should be caused by empty characters in the Plcncli path (C:\\Program Files\\Phoenix Contact\\PLCnCLI 2019.0 LTS) After copying the files to another folder without spaces, it could create the project (see picture) It is also posible to set the path of the project with the -o option. For instance: C:\\Program Files\\Phoenix Contact\\PLCnCLI 2019.0 LTS>plcncli new project -n Proy2 -o C:\\CL3
Thanks, Angel
Hello, empty characters does not have anything to do with this issue. You are running the CLI as a normal user. You need to be admin (run the CMD as admin) to write into “Program Files” in Windows 10. Anyway, I do not recommend to use the PLCnCLI installation folder for your project files. Setup your path variable and call the CLI from anywhere else. About spaces you just need to care about, if you are using them as parameters (e.g. paths) of commands. You always need to set parameters in the command line into quotes, this is due to the fact, that spaces are used as separators of command parameters. - Marcel
