I am using PLCNext AXCF2152. I was able to connect to device from PLCNext Engineer but recently is has stopped responding to PLCNext Engineer. ACF is not loading application either. I tried to restart PLC multiple times but there was no response. Resting plcnext service is giving following error. root@axcf2152:~# /etc/init.d/plcnext restart
Stopping service plcnext
kill: usage: kill [-s sigspec | -n signum | -sigspec] pid | jobspec … or kill -l [sigspec]
Warning: Application with pid does not terminate within 20 seconds.
plcnext stopped
Starting service plcnext
Set plcnext exports
plcnext started (bus system is axioline) Following is the content of /opt/plcnext/logs/Output.log10.12.19 09:26:23.934 Arp.System.Acf.Internal.ApplicationBase INFO - Application 'LocalIoProcess' terminates.
10.12.19 09:26:23.947 CommonRemoting INFO - Remote client disconnects explicitly, connectionId = B1B023F0
10.12.19 09:26:23.949 CommonRemoting INFO - Closing connection: connectionId=B1B023F0
10.12.19 09:26:23.953 CommonRemoting INFO - Remote client disconnects explicitly, connectionId = B1B02CD0
10.12.19 09:26:23.955 CommonRemoting INFO - Closing connection: connectionId=B1B02CD0
10.12.19 09:26:24.928 Arp.System.Acf.Internal.Sm.ProcessesController INFO - Process 'LocalIoProcess' stopped.
10.12.19 09:26:26.433 Arp.System.Acf.Internal.Sm.ProcessesController INFO - Process 'runtime' hard killed.
10.12.19 09:26:26.433 Arp.System.Acf.Internal.Sm.ProcessesController INFO - Process 'runtime' stopped.
10.12.19 09:26:27.475 Arp.System.Acf.Internal.ApplicationBase INFO - ArpVersion: 2020.0 LTS (20.0.0.24752)
10.12.19 09:26:27.484 CommonRemoting INFO - [IpcRemotingBroker]: Starting IPC Remoting Broker
10.12.19 09:26:27.485 CommonRemoting INFO - Starting remoting server (version=4)
10.12.19 09:26:27.485 CommonRemoting INFO - Start listening on TCP port 41120
10.12.19 09:26:27.485 CommonRemoting INFO - Start listening on TCP port 41121
10.12.19 09:26:27.554 Arp.System.Acf.Internal.ApplicationBase FATAL - Fatal error occurs in application 'MainProcess':
10.12.19 09:26:27.555 Arp.System.Acf.Internal.ApplicationBase FATAL - Exception occurs: Exception of type 'Arp::System::Commons::Io::NotExistException' was thrown
Path '/opt/plcnext/projects/Default/Default.acf.config' does not exist.
at: Arp::System::Commons::Xml::XmlConfigDocument::Load(Arp::BasicString const&)
at: Arp::System::Acf::Internal::Sm::Config::AcfConfigurationLoader::Load(Arp::BasicString const&, Arp::BasicString const&, Arp::System::Acf::Internal::Sm::Config::AcfConfiguration&)
at: Arp::System::Acf::Internal::Sm::SystemManager::LoadConfig()
at: Arp::System::Acf::Internal::Sm::SystemManager::SetupSystemSettings()
at: Arp::System::Acf::Internal::Sm::SystemManager::SetupSystem()
at: Arp::System::Acf::Internal::MainApplicationBase::SetupInternal()
at: Arp::System::Acf::Internal::ApplicationBase::Setup(Arp::System::Commons::Diagnostics::Logging::LogLevel, char const*)
at: Arp::System::Acf::Internal::ApplicationBase::Main(int, char**, Arp::System::Commons::Diagnostics::Logging::LogLevel)
at: Arp.System.Application(+0x1c748) [0x4c9748]
at: /lib/libc.so.6(__libc_start_main+0x97) [0xb69dba24]10.12.19 09:28:18.263 Arp.System.Acf.Internal.ApplicationBase INFO - ArpVersion: 2020.0 LTS (20.0.0.24752)
10.12.19 09:28:18.287 CommonRemoting INFO - [IpcRemotingBroker]: Starting IPC Remoting Broker
10.12.19 09:28:18.287 CommonRemoting INFO - Starting remoting server (version=4)
10.12.19 09:28:18.287 CommonRemoting INFO - Start listening on TCP port 41120
10.12.19 09:28:18.287 CommonRemoting INFO - Start listening on TCP port 41121
10.12.19 09:28:18.387 Arp.System.Acf.Internal.ApplicationBase FATAL - Fatal error occurs in application 'MainProcess':
10.12.19 09:28:18.387 Arp.System.Acf.Internal.ApplicationBase FATAL - Exception occurs: Exception of type 'Arp::System::Commons::Io::NotExistException' was thrown
at: Arp.System.Application(+0x1c748) [0x4c0748]
at: /lib/libc.so.6(__libc_start_main+0x97) [0xb69e0a24]10.12.19 09:29:45.857 Arp.System.Acf.Internal.ApplicationBase INFO - ArpVersion: 2020.0 LTS (20.0.0.24752)
10.12.19 09:29:45.867 CommonRemoting INFO - [IpcRemotingBroker]: Starting IPC Remoting Broker
10.12.19 09:29:45.867 CommonRemoting INFO - Starting remoting server (version=4)
10.12.19 09:29:45.867 CommonRemoting INFO - Start listening on TCP port 41120
10.12.19 09:29:45.867 CommonRemoting INFO - Start listening on TCP port 41121
10.12.19 09:29:45.938 Arp.System.Acf.Internal.ApplicationBase FATAL - Fatal error occurs in application 'MainProcess':
10.12.19 09:29:45.938 Arp.System.Acf.Internal.ApplicationBase FATAL - Exception occurs: Exception of type 'Arp::System::Commons::Io::NotExistException' was thrown
at: Arp.System.Application(+0x1c748) [0x42c748]
at: /lib/libc.so.6(__libc_start_main+0x97) [0xb6a33a24]10.12.19 09:30:21.696 Arp.System.Acf.Internal.ApplicationBase INFO - ArpVersion: 2020.0 LTS (20.0.0.24752)
10.12.19 09:30:21.706 CommonRemoting INFO - [IpcRemotingBroker]: Starting IPC Remoting Broker
10.12.19 09:30:21.706 CommonRemoting INFO - Starting remoting server (version=4)
10.12.19 09:30:21.706 CommonRemoting INFO - Start listening on TCP port 41120
10.12.19 09:30:21.706 CommonRemoting INFO - Start listening on TCP port 41121
10.12.19 09:30:21.774 Arp.System.Acf.Internal.ApplicationBase FATAL - Fatal error occurs in application 'MainProcess':
10.12.19 09:30:21.774 Arp.System.Acf.Internal.ApplicationBase FATAL - Exception occurs: Exception of type 'Arp::System::Commons::Io::NotExistException' was thrown
at: Arp.System.Application(+0x1c748) [0x49e748]
at: /lib/libc.so.6(__libc_start_main+0x97) [0xb6a30a24]04.03.20 14:32:12.269 Arp.System.Acf.Internal.ApplicationBase INFO - ArpVersion: 2020.0 LTS (20.0.0.24752)
04.03.20 14:32:12.296 CommonRemoting INFO - [IpcRemotingBroker]: Starting IPC Remoting Broker
04.03.20 14:32:12.297 CommonRemoting INFO - Starting remoting server (version=4)
04.03.20 14:32:12.297 CommonRemoting INFO - Start listening on TCP port 41120
04.03.20 14:32:12.297 CommonRemoting INFO - Start listening on TCP port 41121
04.03.20 14:32:12.396 Arp.System.Acf.Internal.ApplicationBase FATAL - Fatal error occurs in application 'MainProcess':
04.03.20 14:32:12.397 Arp.System.Acf.Internal.ApplicationBase FATAL - Exception occurs: Exception of type 'Arp::System::Commons::Io::NotExistException' was thrown
at: Arp.System.Application(+0x1c748) [0x46c748]
at: /lib/libc.so.6(__libc_start_main+0x97) [0xb69c3a24]04.03.20 14:33:55.423 Arp.System.Acf.Internal.ApplicationBase INFO - ArpVersion: 2020.0 LTS (20.0.0.24752)
04.03.20 14:33:55.433 CommonRemoting INFO - [IpcRemotingBroker]: Starting IPC Remoting Broker
04.03.20 14:33:55.433 CommonRemoting INFO - Starting remoting server (version=4)
04.03.20 14:33:55.433 CommonRemoting INFO - Start listening on TCP port 41120
04.03.20 14:33:55.433 CommonRemoting INFO - Start listening on TCP port 41121
04.03.20 14:33:55.506 Arp.System.Acf.Internal.ApplicationBase FATAL - Fatal error occurs in application 'MainProcess':
04.03.20 14:33:55.506 Arp.System.Acf.Internal.ApplicationBase FATAL - Exception occurs: Exception of type 'Arp::System::Commons::Io::NotExistException' was thrown
at: Arp.System.Application(+0x1c748) [0x511748]
at: /lib/libc.so.6(__libc_start_main+0x97) [0xb6a72a24]04.03.20 14:34:29.571 Arp.System.Acf.Internal.ApplicationBase INFO - ArpVersion: 2020.0 LTS (20.0.0.24752)
04.03.20 14:34:29.581 CommonRemoting INFO - [IpcRemotingBroker]: Starting IPC Remoting Broker
04.03.20 14:34:29.581 CommonRemoting INFO - Starting remoting server (version=4)
04.03.20 14:34:29.581 CommonRemoting INFO - Start listening on TCP port 41120
04.03.20 14:34:29.581 CommonRemoting INFO - Start listening on TCP port 41121
04.03.20 14:34:29.650 Arp.System.Acf.Internal.ApplicationBase FATAL - Fatal error occurs in application 'MainProcess':
04.03.20 14:34:29.650 Arp.System.Acf.Internal.ApplicationBase FATAL - Exception occurs: Exception of type 'Arp::System::Commons::Io::NotExistException' was thrown
at: Arp.System.Application(+0x1c748) [0x45c748]
at: /lib/libc.so.6(__libc_start_main+0x97) [0xb69d1a24]04.03.20 14:41:15.998 Arp.System.Acf.Internal.ApplicationBase INFO - ArpVersion: 2020.0 LTS (20.0.0.24752)
04.03.20 14:41:16.008 CommonRemoting INFO - [IpcRemotingBroker]: Starting IPC Remoting Broker
04.03.20 14:41:16.008 CommonRemoting INFO - Starting remoting server (version=4)
04.03.20 14:41:16.009 CommonRemoting INFO - Start listening on TCP port 41120
04.03.20 14:41:16.009 CommonRemoting INFO - Start listening on TCP port 41121
04.03.20 14:41:16.078 Arp.System.Acf.Internal.ApplicationBase FATAL - Fatal error occurs in application 'MainProcess':
04.03.20 14:41:16.078 Arp.System.Acf.Internal.ApplicationBase FATAL - Exception occurs: Exception of type 'Arp::System::Commons::Io::NotExistException' was thrown
at: Arp.System.Application(+0x1c748) [0x42d748]
at: /lib/libc.so.6(__libc_start_main+0x97) [0xb69b6a24]Please suggest how to make PLC work again.
