On the bottom there is a tab called Hide/Show GLOBAL FIND AND REPLACE On the Find what type in AnalogInput and hit the magnifying lens. It will then crash. I am not able to attach the program to this submission. I am able to provide the program. PLCnext Engineer, Version 2021.0.2 (Build 4.7.1183.0) Unexpected Exception ====================================================================== Value cannot be null. Parameter name: terminalTypeConfiguration Exception chain: ---------------------------------------------------------------------- ArgumentNullException ====================================================================== Details ---------------------------------------------------------------------- ArgumentNullException ============================== Message: ------------------------------ Value cannot be null. Parameter name: terminalTypeConfiguration Stack trace: ------------------------------ at Ade.Network.StationEditor.StationEditorConfiguration.a(TerminalTypeConfiguration A_0) at Ade.Network.StationEditor.StationEditorModel.i() at c3y.a(IDocument A_0, Lazy1 A_1, Lazy1 A_2, Lazy1 A_3, Lazy1 A_4, Lazy1 A_5, Lazy1 A_6, Lazy1 A_7, Lazy1 A_8, Lazy1 A_9, Lazy1 A_10, Lazy1 A_11, Lazy1 A_12, Lazy`1 A_13) at Ade.Network.StationEditor.Search.StationEditorSearcherFactory.CreateSearcher(IDocument document) at Ade.Documents.SearcherProvider.GetSearcher(IDocument document) at Ade.Documents.SearchEngine.d.a() at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler) at System.Windows.Threading.DispatcherOperation.InvokeImpl() at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Threading.DispatcherOperation.Invoke() at System.Windows.Threading.Dispatcher.ProcessQueue() at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler) at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg) at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) at System.Windows.Application.RunDispatcher(Object ignore) at System.Windows.Application.RunInternal(Window window) at Ade.Application.ApplicationStarter.Run() at (String ) at PCWorxNext.Startup.Main(String args)
Sorry for the delay. The behaviour you descibe has been identified as a bug in PLCnext Engineer, and will be fixed in version 2021.3. (ref: 208932)
