PLCnext Engineer 2022.0: Issues Saving to Network Drive
I am having an issue with 2022.0 that I did not experience with previous versions. I typically work with projects stored on a mapped network drive. The problem is, changes are not saved every time. I have not been able to narrow it down to a specific sequence of events that causes the issue.
The date modified property of the file updates every time, but the changes are not always there.
I also had issues when doing a save as. Steps:
[list=1]
[] Save as to local disk
] The network file was never saved (even though I saved before save as)
[] The new file on local disk did not have the changes
] The network file stayed locked until closing PLCnext Engineer
[*] Re-opening the local project triggered the “…abnormal termination…” prompt. That file was the only one that had the latest changes.
[/list]
EDIT: On a positive note, I am able to send sources from the project stored on the network drive. That was an issue I had with 2021.3 to 2021.9.
I’m seeing this behavior, as well. Specifically within a virtual machine’s shared folder.
There are changes in the upcoming PLCnext Engineer version 2022.3, which will also be included in version 2023.0 LTS, that are expected to fix this issue.
Glad to hear it. I’ll test it as soon as I see the release.
Thank you for the update, Martin.
