Hey everyone,
I’m relatively new to working with this type of PLC, so I’ve been diligently following the manual. Following its instructions, I’ve added a pre-existing template: “AXC F 1152 v00 / 2021.0.0”. Subsequently, I attempted to locate the physical controller I’m connected to.
Initially, I conducted a ping to the address 192.168.1.10, and it responded correctly (in my network, the controller is the only device). After confirming that my PC detects the controller, I checked the IP in my project on the PC, which matches the physical one.
However, when I look for available controllers in “online controllers,” nothing appears. Strangely though, in the “online state” window, there’s a controller to which I can connect after entering the username and password. (I saved my project before and after connecting)
The real issue arises when I attempt to create a simple program; the software crashes and shuts down. Below, I’ve attached a text file with the diagnostic details.
Some information:
-PLC: AXC F 1152
-PLC status:
All lights off except: BF_D (red blinking), RUN (initially green but I can make it blink by sending a stop signal from the software), D (orange).
-PLCnext Engieener: 2021.3.1
Any insights or suggestions would be greatly appreciated.
errorReport.txt
