In TIA Portal, there is a High Speed Counter technology object, which allows to derive a rotary speed from a high-frequent pulse input signal through the TM Count module.
Is there a similar concept in PLCNext Engineer?
Upfront thanks!
Here is the answer from the Controls support team:
PLCnext Engineer does not provide high speed FB for counting rotary speed devices. I think the customer first needs an AXL IO module (maybe CNT) for this and can then see whether there are also FBs available for this in the PLCnext Store.
