Hello, the PLCnext Error Parser Eclipse configuration to work correctly require some pattern modification: instead of
\\[cmake\\]:(.*?):(\\d+):(\\d+:)? .*\\(Each undeclared identifier is reported only once.*it should be
\\[cmake\\]:\\s*(.*?):(\\d+):(\\d+:)? .*\\(Each undeclared identifier is reported only once.*Other patterns should be corrected the same. It is because of extra white space after [cmake]:
[cmake]: /home/id/ptusa_git/PAC_control_projects/main_control_prg/eclipse/projects/PLCnext-linux-PLCnextEngineer/src/PtusaMainPrg.cpp:71:37: error: ‘ng’ was not declared in this scope
