Good Afternoon, My team and I were doing some tests with the PLCNext, trying to use MQTT protocolo, so we try to install Node.js app from PCnext Store and install it, and also using Node-Red, but it got stuck with RUN, FAIL and D LED are ON. We try to access from the web server, but we can´t, and we try to uninstall the aplications, and restart the firmware, but even withh that action, we can’t restore it to it’s normal funtion. I extract the last log file, so maybe it can help with the solution. I will appreciate some help 09.06.21 14:25:48.330 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Event Archive Entry 09.06.21 14:25:48.330 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Module ID: 8b, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_WARNING 09.06.21 14:25:48.330 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Message: Could not get receive thread prio from section the [IPCONFIGx] section. 09.06.21 14:25:48.331 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Event Archive Entry 09.06.21 14:25:48.331 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Module ID: 80, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_WARNING 09.06.21 14:25:48.331 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Message: OSL_CreateTask: Could not get default stack size from ini file, using default stack size 8388608 09.06.21 14:25:48.333 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Event Archive Entry 09.06.21 14:25:48.333 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Module ID: 80, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_WARNING 09.06.21 14:25:48.333 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Message: OSL_CreateTask: Could not get default stack size from ini file, using default stack size 8388608 09.06.21 14:25:48.334 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Event Archive Entry 09.06.21 14:25:48.334 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Module ID: 80, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_WARNING 09.06.21 14:25:48.334 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Message: OSL_CreateTask: Could not get default stack size from ini file, using default stack size 8388608 09.06.21 14:25:48.336 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Event Archive Entry 09.06.21 14:25:48.336 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Module ID: 80, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_WARNING 09.06.21 14:25:48.336 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Message: OSL_CreateTask: Could not get default stack size from ini file, using default stack size 8388608 09.06.21 14:25:48.365 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Event Archive Entry 09.06.21 14:25:48.365 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Module ID: 0, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_WARNING 09.06.21 14:25:48.365 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Message: module 0x47 disabled 09.06.21 14:25:48.366 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Event Archive Entry 09.06.21 14:25:48.366 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Module ID: 0, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_WARNING 09.06.21 14:25:48.366 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Message: module 0x36 disabled 09.06.21 14:25:48.366 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Event Archive Entry 09.06.21 14:25:48.366 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Module ID: 0, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_WARNING 09.06.21 14:25:48.366 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Message: module 0x57 disabled 09.06.21 14:25:48.366 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Event Archive Entry 09.06.21 14:25:48.366 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Module ID: 0, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_WARNING 09.06.21 14:25:48.366 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Message: module 0x51 disabled 09.06.21 14:25:48.366 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Event Archive Entry 09.06.21 14:25:48.366 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Module ID: 0, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_WARNING 09.06.21 14:25:48.366 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Message: module 0x50 disabled 09.06.21 14:25:48.366 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Event Archive Entry 09.06.21 14:25:48.366 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Module ID: 0, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_WARNING 09.06.21 14:25:48.366 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Message: module 0x52 disabled 09.06.21 14:25:48.366 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Event Archive Entry 09.06.21 14:25:48.366 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Module ID: 0, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_WARNING 09.06.21 14:25:48.367 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Message: module 0x53 disabled 09.06.21 14:25:48.367 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Event Archive Entry 09.06.21 14:25:48.367 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Module ID: 0, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_WARNING 09.06.21 14:25:48.367 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Message: module 0x72 disabled 09.06.21 14:25:48.367 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Event Archive Entry 09.06.21 14:25:48.367 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Module ID: 0, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_WARNING 09.06.21 14:25:48.367 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Message: module 0x55 disabled 09.06.21 14:25:48.367 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Event Archive Entry 09.06.21 14:25:48.367 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Module ID: 0, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_WARNING 09.06.21 14:25:48.367 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Message: module 0x71 disabled 09.06.21 14:25:48.367 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Event Archive Entry 09.06.21 14:25:48.367 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Module ID: 0, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_WARNING 09.06.21 14:25:48.367 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Message: module 0x54 disabled 09.06.21 14:25:48.367 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Event Archive Entry 09.06.21 14:25:48.367 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Module ID: 81, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_WARNING 09.06.21 14:25:48.367 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Message: OSL_MH_Init: Could not get MH message queue access timeout from ini file, using default timeout 20 09.06.21 14:25:48.368 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Event Archive Entry 09.06.21 14:25:48.368 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Module ID: 81, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_WARNING 09.06.21 14:25:48.368 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Message: OSL_MH_Init: Could not get MH client connection data access timeout from ini file, using default timeout 20 09.06.21 14:25:48.368 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Event Archive Entry 09.06.21 14:25:48.368 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Module ID: 81, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_WARNING 09.06.21 14:25:48.368 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Message: OSL_MH_Init: Could not get MH timeout detection thread prio from ini file. 09.06.21 14:25:48.368 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Event Archive Entry 09.06.21 14:25:48.368 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Module ID: 80, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_WARNING 09.06.21 14:25:48.368 Arp.Io.ProfinetStack.System.Internal.Adaption WARN - Message: OSL_CreateTask: Could not get default stack size from ini file, using default stack size 8388608 09.06.21 14:26:40.380 Arp.System.Rsc.Internal.Remoting.RscServiceStubAdapter ERROR - Exception occurs while invoking service method ‘Arp.System.Acf.Services.Internal.IProcessManagerService:8’: Initialize: ProfinetStack could not be initialized after 50 seconds. Exception of type ‘Arp::System::Commons::InvalidConfigException’ was thrown \t at: Arp::System::Acf::Internal::Pm::ProcessManager::SetupComponentSettings(Arp::BasicString > const&) \t at: Arp::System::Acf::Services::Internal::ProcessManagerServiceImpl::SetupComponentSettings(Arp::System::Rsc::Services::RscString<512> const&) \t at: Arp::System::Acf::Services::Internal::ProcessManagerServiceStub::SetupComponentSettings(Arp::System::Rsc::Services::RscServerContext&) \t at: Arp::System::Acf::Services::Internal::ProcessManagerServiceStub::Invoke(int, Arp::System::Rsc::Services::RscServerContext&) \t at: Arp::System::Rsc::Internal::Remoting::RscServiceStubAdapter::Invoke(int, CommonRemoting::RemotingServerContext&) \t at: CommonRemoting::RemotingServiceBase::Invoke(CommonRemoting::RemotingServerContext&) \t at: CommonRemoting::ServiceInvocationSink::ProcessRequest(CommonRemoting::RemotingServerSession&, CommonRemoting::RemotingServerContext&) \t at: CommonRemoting::RemotingServiceBrokerSink::ProcessInvokeServiceCommand(CommonRemoting::RemotingServerSession&, CommonRemoting::RemotingServerContext&) \t at: CommonRemoting::RemotingServiceBrokerSink::ProcessRequest(CommonRemoting::RemotingServerSession&, CommonRemoting::RemotingServerContext&) \t at: CommonRemoting::RemotingServerSession::ProcessInternal() \t at: CommonRemoting::RemotingServerSession::RunSession(void*) \t at: CommonRemoting::RemotingThreadBase::RunInternal(void*) \t at: /usr/lib/libCommonRemoting.so(+0x26140) [0xb6e9a140] 09.06.21 14:26:40.380 CommonRemoting ERROR - RemotingContext::AbortInvocation(): connectionID=00054868, errorCode=2000000A, message: Initialize: ProfinetStack could not be initialized after 50 seconds. 09.06.21 14:26:42.610 Arp.Io.ProfinetStack.System.Internal.System WARN - Could not get ‘VendorID’ from configuration file, Variable not found in [[I&M0;]]! 09.06.21 14:26:42.612 Arp.Io.ProfinetStack.System.Internal.System WARN - Could not get ‘SwRevPrefix’ from configuration file, Variable not found in [I&M0;]! 09.06.21 14:26:42.614 Arp.Io.ProfinetStack.System.Internal.System WARN - Could not get ‘ProfileID’ from configuration file, Variable not found in [I&M0;]! 09.06.21 14:26:42.614 Arp.Io.ProfinetStack.System.Internal.System WARN - Could not get ‘ProfileSpecType’ from configuration file, Variable not found in [I&M0;]! 09.06.21 14:26:42.615 Arp.Io.ProfinetStack.System.Internal.System WARN - Could not get ‘ImVerMajor’ from configuration file, Variable not found in [I&M0;]! 09.06.21 14:26:42.615 Arp.Io.ProfinetStack.System.Internal.System WARN - Could not get ‘ImVerMinor’ from configuration file, Variable not found in [I&M0;]! 09.06.21 14:26:42.615 Arp.Io.ProfinetStack.System.Internal.System WARN - Could not get ‘ImSupported’ from configuration file, Variable not found in [I&M0;]! 09.06.21 14:26:42.616 Arp.Io.ProfinetStack.Controller.Internal.Controller ERROR - CM_GetConfigVar() returned 0x2566, using default ARCountMax = 32 09.06.21 14:26:42.616 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Event Archive Entry 09.06.21 14:26:42.616 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Module ID: 71, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_ERROR 09.06.21 14:26:42.616 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Message: PN_CTRL_AddInstance: Global controller instance list not initialized. 09.06.21 14:26:42.622 Arp.System.Rsc.Internal.Remoting.RscServiceStubAdapter ERROR - Exception occurs while invoking service method ‘Arp.System.Acf.Services.Internal.IProcessManagerService:8’: PN_AddCtrlInst failed, dwRet = 0x604! Exception of type ‘Arp::System::Commons::InvalidOperationException’ was thrown \t at: Arp::Io::ProfinetStack::Controller::ControllerComponent::SetupSettings() \t at: Arp::System::Acf::Internal::Pm::ProcessManager::SetupComponentSettings(Arp::BasicString > const&) \t at: Arp::System::Acf::Services::Internal::ProcessManagerServiceImpl::SetupComponentSettings(Arp::System::Rsc::Services::RscString<512> const&) \t at: Arp::System::Acf::Services::Internal::ProcessManagerServiceStub::SetupComponentSettings(Arp::System::Rsc::Services::RscServerContext&) \t at: Arp::System::Acf::Services::Internal::ProcessManagerServiceStub::Invoke(int, Arp::System::Rsc::Services::RscServerContext&) \t at: Arp::System::Rsc::Internal::Remoting::RscServiceStubAdapter::Invoke(int, CommonRemoting::RemotingServerContext&) \t at: CommonRemoting::RemotingServiceBase::Invoke(CommonRemoting::RemotingServerContext&) \t at: CommonRemoting::ServiceInvocationSink::ProcessRequest(CommonRemoting::RemotingServerSession&, CommonRemoting::RemotingServerContext&) \t at: CommonRemoting::RemotingServiceBrokerSink::ProcessInvokeServiceCommand(CommonRemoting::RemotingServerSession&, CommonRemoting::RemotingServerContext&) \t at: CommonRemoting::RemotingServiceBrokerSink::ProcessRequest(CommonRemoting::RemotingServerSession&, CommonRemoting::RemotingServerContext&) \t at: CommonRemoting::RemotingServerSession::ProcessInternal() \t at: CommonRemoting::RemotingServerSession::RunSession(void*) \t at: CommonRemoting::RemotingThreadBase::RunInternal(void*) \t at: /usr/lib/libCommonRemoting.so(+0x26140) [0xb6e9a140] 09.06.21 14:26:42.622 CommonRemoting ERROR - RemotingContext::AbortInvocation(): connectionID=00054868, errorCode=2000000A, message: PN_AddCtrlInst failed, dwRet = 0x604! 09.06.21 14:26:44.853 Arp.Io.ProfinetStack.System.Internal.System WARN - Could not get ‘VendorID’ from configuration file, Variable not found in [[I&M0;]]! 09.06.21 14:26:44.855 Arp.Io.ProfinetStack.System.Internal.System WARN - Could not get ‘SwRevPrefix’ from configuration file, Variable not found in [I&M0;]! 09.06.21 14:26:44.856 Arp.Io.ProfinetStack.System.Internal.System WARN - Could not get ‘ProfileID’ from configuration file, Variable not found in [I&M0;]! 09.06.21 14:26:44.857 Arp.Io.ProfinetStack.System.Internal.System WARN - Could not get ‘ProfileSpecType’ from configuration file, Variable not found in [I&M0;]! 09.06.21 14:26:44.857 Arp.Io.ProfinetStack.System.Internal.System WARN - Could not get ‘ImVerMajor’ from configuration file, Variable not found in [I&M0;]! 09.06.21 14:26:44.858 Arp.Io.ProfinetStack.System.Internal.System WARN - Could not get ‘ImVerMinor’ from configuration file, Variable not found in [I&M0;]! 09.06.21 14:26:44.858 Arp.Io.ProfinetStack.System.Internal.System WARN - Could not get ‘ImSupported’ from configuration file, Variable not found in [I&M0;]! 09.06.21 14:26:44.861 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Event Archive Entry 09.06.21 14:26:44.862 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Module ID: 0, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_ERROR 09.06.21 14:26:44.862 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Message: CTM CTM_UTIL_AddCmdevInst(): Error retrieving entry ‘StationNameLen’ from section ‘[CMDEV1]’ 09.06.21 14:26:44.862 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Event Archive Entry 09.06.21 14:26:44.863 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Module ID: 71, Zone: EA_ZONE_RETAIL, EntryType: EA_TYPE_ERROR 09.06.21 14:26:44.863 Arp.Io.ProfinetStack.System.Internal.Adaption ERROR - Message: PN_DEV_AddInstance: CTM CTM_UTIL_AddCmdevInst() returned with errors 09.06.21 14:26:44.869 Arp.System.Rsc.Internal.Remoting.RscServiceStubAdapter ERROR - Exception occurs while invoking service method ‘Arp.System.Acf.Services.Internal.IProcessManagerService:8’: AddPnDevice: PN_AddDevInst, dwRet = 0x500a06 Exception of type ‘Arp::System::Commons::InvalidOperationException’ was thrown \t at: Arp::Io::ProfinetStack::Device::DeviceComponent::SetupSettings() \t at: Arp::System::Acf::Internal::Pm::ProcessManager::SetupComponentSettings(Arp::BasicString > const&) \t at: Arp::System::Acf::Services::Internal::ProcessManagerServiceImpl::SetupComponentSettings(Arp::System::Rsc::Services::RscString<512> const&) \t at: Arp::System::Acf::Services::Internal::ProcessManagerServiceStub::SetupComponentSettings(Arp::System::Rsc::Services::RscServerContext&) \t at: Arp::System::Acf::Services::Internal::ProcessManagerServiceStub::Invoke(int, Arp::System::Rsc::Services::RscServerContext&) \t at: Arp::System::Rsc::Internal::Remoting::RscServiceStubAdapter::Invoke(int, CommonRemoting::RemotingServerContext&) \t at: CommonRemoting::RemotingServiceBase::Invoke(CommonRemoting::RemotingServerContext&) \t at: CommonRemoting::ServiceInvocationSink::ProcessRequest(CommonRemoting::RemotingServerSession&, CommonRemoting::RemotingServerContext&) \t at: CommonRemoting::RemotingServiceBrokerSink::ProcessInvokeServiceCommand(CommonRemoting::RemotingServerSession&, CommonRemoting::RemotingServerContext&) \t at: CommonRemoting::RemotingServiceBrokerSink::ProcessRequest(CommonRemoting::RemotingServerSession&, CommonRemoting::RemotingServerContext&) \t at: CommonRemoting::RemotingServerSession::ProcessInternal() \t at: CommonRemoting::RemotingServerSession::RunSession(void*) \t at: CommonRemoting::RemotingThreadBase::RunInternal(void*) \t at: /usr/lib/libCommonRemoting.so(+0x26140) [0xb6e9a140] 09.06.21 14:26:44.869 CommonRemoting ERROR - RemotingContext::AbortInvocation(): connectionID=00054868, errorCode=2000000A, message: AddPnDevice: PN_AddDevInst, dwRet = 0x500a06 09.06.21 14:26:44.903 Arp.Services.ProfiCloud.Internal.ProficloudTSDSettings WARN - Could not parse ProfiCloud settings 09.06.21 14:26:44.912 Arp.Device.Interface.Internal.DeviceSettings INFO - DiUserConfigurationDocument at ‘/opt/plcnext/projects/Default/Device/Interface/Di.User.config’ not found 09.06.21 14:26:44.914 CommonRemoting INFO - Starting remoting server (version=4) 09.06.21 14:26:44.915 CommonRemoting INFO - Start listening on TCP port 41108 09.06.21 14:26:44.919 CommonRemoting INFO - Starting remoting server (version=4) 09.06.21 14:26:44.919 CommonRemoting INFO - Start listening on TCP port 41109 09.06.21 14:26:44.923 root WARN - Cannot resolve /opt/plcnext/projects/PCWE/Plc/Meta/.meta.config: Directory does not exist. 09.06.21 14:26:45.609 Arp.System.Acf.Internal.Sm.ComponentsController ERROR - Exception occurs while setting up config of component ‘Arp.Plc.Eclr’: Could not load eCLR image file: ‘/opt/plcnext/projects/PCWE/Plc/Eclr/eCLR.img’ Exception of type ‘Arp::System::Commons::InvalidOperationException’ was thrown \t at: Arp::Plc::Eclr::EclrComponent::LoadPlc(bool) \t at: Arp::Plc::Eclr::EclrComponent::LoadConfig() \t at: Arp::System::Acf::Internal::Pm::ProcessManager::LoadComponentConfig(Arp::BasicString > const&) \t at: Arp::System::Acf::Services::Internal::ProcessManagerServiceImpl::LoadComponentConfig(Arp::System::Rsc::Services::RscString<512> const&) \t at: Arp::System::Acf::Internal::Sm::ComponentsController::SetupComponentConfig(Arp::System::Acf::Internal::Sm::Data::ComponentExecutionData&) \t at: Arp::System::Acf::Internal::Sm::ComponentsController::SetupComponentsConfig() \t at: Arp::System::Acf::Internal::Sm::SystemManager::SetupSystem() \t at: Arp::System::Acf::Internal::ApplicationBase::SetupSystem() \t at: Arp::System::Acf::Internal::MainApplicationBase::SetupInternal() \t at: Arp::System::Acf::Internal::ApplicationBase::Setup(Arp::System::Commons::Diagnostics::Logging::LogLevel, char const) \t at: Arp::System::Acf::Internal::ApplicationBase::Main(int, char**, Arp::System::Commons::Diagnostics::Logging::LogLevel) \t at: Arp.System.Application() [0x1a5fc] 09.06.21 14:26:45.610 Arp.System.Acf.Internal.Sm.ComponentsController ERROR - Exception occurs while setting up config of component ‘Arp.Plc.Eclr’: Could not load eCLR image file: ‘/opt/plcnext/projects/PCWE/Plc/Eclr/eCLR.img’ Exception of type ‘Arp::System::Commons::InvalidOperationException’ was thrown \t at: Arp::Plc::Eclr::EclrComponent::LoadPlc(bool) \t at: Arp::Plc::Eclr::EclrComponent::LoadConfig() \t at: Arp::System::Acf::Internal::Pm::ProcessManager::LoadComponentConfig(Arp::BasicString > const&) \t at: Arp::System::Acf::Services::Internal::ProcessManagerServiceImpl::LoadComponentConfig(Arp::System::Rsc::Services::RscString<512> const&) \t at: Arp::System::Acf::Internal::Sm::ComponentsController::SetupComponentConfig(Arp::System::Acf::Internal::Sm::Data::ComponentExecutionData&) \t at: Arp::System::Acf::Internal::Sm::ComponentsController::SetupComponentsConfig() \t at: Arp::System::Acf::Internal::Sm::SystemManager::SetupSystem() \t at: Arp::System::Acf::Internal::ApplicationBase::SetupSystem() \t at: Arp::System::Acf::Internal::MainApplicationBase::SetupInternal() \t at: Arp::System::Acf::Internal::ApplicationBase::Setup(Arp::System::Commons::Diagnostics::Logging::LogLevel, char const*) \t at: Arp::System::Acf::Internal::ApplicationBase::Main(int, char**, Arp::System::Commons::Diagnostics::Logging::LogLevel) \t at: Arp.System.Application() [0x1a5fc] 09.06.21 14:26:45.647 Arp.System.Um.Internal.LinuxUserProvider INFO - Export of um users to Linux system started 09.06.21 14:26:45.649 Arp.System.Um.Internal.LinuxUserProvider INFO - user ‘admin’ selected for export 09.06.21 14:26:45.844 Arp.System.Um.Internal.LinuxUserProvider INFO - Export of um users to Linux system finished 09.06.21 14:26:45.848 Arp.Io.Axioline.AxiolineComponent INFO - Axioline: Start. 09.06.21 14:26:45.874 CommonRemoting INFO - Starting remoting server (version=4) 09.06.21 14:26:45.875 CommonRemoting INFO - Start listening on TCP port 41100 09.06.21 14:26:45.876 Arp.Services.ProfiCloud.Internal.ProficloudTSDAdapter INFO - No metrics configured. Will not connect to Proficloud. 09.06.21 14:26:45.879 Arp.System.Acf.Internal.ApplicationBase INFO - Application ‘MainApplication’ was setup successfully.
Firstly, to get the PLC back to working order you can try a Type 1 reset, which should clear all the user files including the PLCnext Engineer project and any installed apps. Please let us know if this works. Secondly, I don’t know what caused this behaviour. If you suspect it was the Node.js app, then normally you would get support from the app developers, who you can reach using the “Contact” button on the app page in the PLCnext Store. In this case, it looks like the Node.js app is no longer in the PLCnext Store, so this won’t be possible. It seems like other users have had success installing Node.js in an OCI container: https://www.plcnext-community.net/en/hn-makers-blog/481-node-red-and-getting-started-with-docker.html https://www.plcnext-community.net/en/hn-makers-blog/482-node-red-with-docker-tips-and-best-practice.html Balena Engine is now included with the latest firmware versions, so this does not need to be installed separately.
