Hi! I’m using a very old version of PLCnext controller AXC F 2152 with firmware version 1.0.2.7. When I go to the webpage, I only see a few options but there is no way to update te firmware on that page. PLCnext Engineer won’t connect to the controller because of the old version. Is there a way to update the firmware of this controller? Thanks in advance!
yes sure.
This procedure should solve the issue. https://dhgz5r09n5kf6.cloudfront.net/107708_en_02/Appendix_A/Appendix_A.htm?rhhlterm=update&rhsyns;=%20
After updating to 2020.X you will properbly have to execute a type 1 reset as well. https://www.plcnext-community.net/en/hn-knowledge-base/hn-faq.html?view=faq&tmpl;=component&window;=1&faqid;=57
Thank you for the help! Indeed, this was the solution.
Link is broken. Can you reup?
