PLCnext to Azure IoT Hub-Using PLCnext Edge Gateway
I a trying to exchange the data from PLCnext to Azure Iot Hub using PLCnext Edge gateway. I am able to connect with Azure IoT Hub . On the Dashboard able to see Cloud connection status “Connected”.In Drivers – DSlinks-- dslink-plcnext-api is enabled.dslink-node-azure is also enabled.but in Driver I am able to see only three drivers 1.Sparkplug,2EthernetIp,3.Modbus.
Now I am trying to add metrics then Node where in select node I saw three option Sys,data,downstream
In PLCnext engineer I created 3 variables with LOCAL and HMI .
So as per document expected below data folder dslink-plcnext-api with these variables but it’s not showing .
Can you help to rectify this issue ?
Please use the “Contact Support” button in the Edge Gateway app to get support with that application.
