Hello Phoenix employees, I had a presentation as my intership ends this week. My schoolteacher asked the question:What is the reason somebody would pick a PLCnext over a microcontroller. We had a short discussion with all the attenders and came up with some conclusions, but personally I would like to know what Phoenix thinks about that! Thanks in advance, Arne Smets
Hi Arne, By “microcontroller” I assume the questioner was referring to a general-purpose single board computer like a Raspberry Pi ? Some benefits of PLCnext over these types of microcontrollers include (in approximate order from most to least compelling, in my opinion):
* The ability to run deterministic, real-time applications. This is provided by the PREEMPT-RT Linux patch. * Hardware features like industrial housing, wide temperature range, shock resistance, ability to connect industrial I/O modules directly to the CPU, etc. * The PLCnext Runtime. This is a process that runs on every PLCnext Control device, and includes: * The ability to easily schedule real-time tasks and programs, using the Execution and Synchonisation Manager (ESM). * The ability to easily transfer data between separate real-time and non-real tasks, using the Global Data Space (GDS). * Many additional industrial services like access to local and remote I/O, an OPC UA Server, Proficloud-TSD service, etc. * The ability to extend the PLCnext Runtime with your own components and services written in your language of choice. * The PLCnext Store. * The ability to develop a single automation software project using any combination of IEC 61131, C++, C#, and other languages. * The ability to treat the device simply like any other "traditional" IEC 61131 PLC, if that's what you are comfortable with.I think that all of the above features are completely absent from most general-purpose microcontrollers. If none of these features are important for a particular application, then a general-purpose microcontroller might be a better choice.
Just my 2c. ~ Martin. P.S. I hope you enjoyed using PLCnext during your internship, and best of luck in the future!
Thanks Martin, clear answer! I liked my internship a lot, even while it was quite hard to understand some things. Never worked with PLC’s before september, only with embedded software (mplab C). The company has a new student who will follow me up in the same project, as I will probably stay and help him out sometimes. Thanks for all the responses, as it was not really possible to ask my questions in the company itself (because PLCnext is a new oppertunity and nobody really worked with it before). Arne
