PLCnext WBM Profinet status
Hi. I’m running a Profinet system with 3 PLCnext PLCs and 2 BK’s.
in the WBM it says Diagnostic code 0x0020 and flashes Green/Orange: Peripheral Errors
Status | Warning
Diagnostics Status: Code | 0x0020
Diagnostics Status: Bit 5: Neighborhood information is not available | Bit 5: Neighborhood information is not available
is it possible to remove that warning? Everything seems to work, fine. - Emil
Hi Emil, There is more information on the cause of that warning in the Info Center: https://www.plcnext.help/te/WBM/PROFINET_diagnostic_code_in_WBM.htm I am afraid that it is not possible to suppress that warning. Regards,
Martin.
