Hello, I am using the PLCnextBase_1_0 library and trying to use the PBCL_DateTimeSet_1 block. I am able to read the time, but when I try to change the time using the Function Block nothing happens to the time. I am using: AXC F 2152 FW 2020.3 PLCnext Engineer 2020.3 Hotfix PLCnextBase_1_0 PLCnextBaseServices All other blocks seem to function correctly but this one in the Date and Time category. Thanks!
Hello Dan,
you are using the latest version available build for 2020.3 correct?
It should be version PLCnextbase_1_1_0 ? https://s3.eu-central-1.amazonaws.com/plcnext-store-prod/doc/PLCnextBase_1_1_FBFun-20190917105610.pdfNothing at all happens or do you at least get some error codes?
I will have to investigate this behavior.
Edit:
This is a bug for FW 2020.3 it will be solved by FW 2020.6.
Sorry for the inconvenience.kind regards,
