Hi, I noticed that if I use the function block PBCL_SysRestart_1 from PLCNextBase library I loose the possibility to download changes, I have to download everything. Is this a known issue or is it just a problem in my project? I am using RFC4072s with fw 2020.0 LTS Best regards Stefan
Hello Stefan, I assume you are unsing PLCnextBase 1.1. Use in the meaning of “instanciating” or “executing”? In case of “executing”: The function block calls the DeviceControl.RestartDevice RSC service. Reaction of PLCnext Engineer is out of scope of the library. Kind regards
Hi Stefan, Can you please give us detailed steps on how to reproduce this problem? Please include the version of PLCnext Engineer you are using. ~ Martin.
Hi! “D.Simon” The function block is working fine, the problem is that that the PLC has to go to stop when I am downloading the project. “Martin” I made a new project and tried just to implement the restart block and then it worked fine with downloading changes. But when I also implemented the SysNetwork block the download changes was not possible. If I removed the restart block and kept the SysNetwork block I could download changes again. Maybe it is when I combine the 2 blocks the PLC has problem to activate the downloaded project. I’am using 2020.3 /Stefan
Hello Stefan, as far as I’m in my investigations I want to give you some feedback. The behavior is also reproducable with just the function block. I reported this as defect 466-2048 of the library and hope can be fixed with the next release which is planned for end of this month. Greetings
Hello D.Simon! Thanks for update, that sounds good. Br Stefan
