Hi, I downloaded https://www.plcnextstore.com/#/192 and tried to use the block PNFD_IL_DIAG and in manual it refers to AsynCom_PN_Info_V1_01. I can’t find that block in the folders. I have downloaded the asyncom library but it is not in that library as well. Best regards Stefan
This is a documentation error. AsynCom_PN_Info* does only exist in PC Worx 6, not in PLCnext Engineer.
Should I use some other block to read all profinet devices or is it not possible to use PNFD_IL_DIAG in plcnext? Br Stefan
It is possible to use PNFD_IL_DIAG like this: 8 PNFD_IL_Diag … Then we have to fill out the FDestAddr and the SlotID for the safety module. Here we have the safety module on
slot 3 at the first bus coupler and on slot 1 at the second bus coupler. The first safety module has the FDestAddr
33 with the NodeID 90 and the second FDestAddr 35 with NodeID 112. In PC Worx 6 this is done by AsynCom_PN_Info. But this is technically not possible in PLCnext. That AsynCom_PN_Info was mentioned in the PLCnext documentation was a mistake because the PLCnext documentation was created from the PC Worx 6 documentation. Best regards, Oliver
Ok. then it should be possible to read diagnostic to PLC software. What about the data type ASYN_ARR_DEVICES_PN_0_255, I get error is inaccessible on that data type. /Stefan
ASYN_ARR_DEVICES_PN_0_255 is provided by the AsynCom library and used in PN_Dev_Diag. If you include PN_Dev_Diag_4 in your PLCnext project it should work. If you want to use ASYN_ARR_DEVICES_PN_0_255 directly in your PLCnext project you have to include AsynCom_9 in your PLCnext project too. AsynCom_9.pcwlx is includes in the MSI file (https://www.plcnextstore.com/#/192, PLCNE_PN_Dev_Diag_4_20200305.msi) too. If there are any more problems please send your PLCnext project to automation-service@phoenixcontact.com with the call number 00128406 in the subject of your email. Thank you and kind regards, Oliver
