I think that “Pump Station Control” is a good simple solution app to show customers how PLCnext Store works, but after testing it I have following doubts about it. 1) First of all, the documentation that can be downloaded from the PLCnext Store for this application is in my opinion insufficient. There is no information about which signals must be connected and which are optional. In the case of binary inputs there is also no description explaining the function of the inputs. For example, I don’t know what the “Impulse Flow” input is for. Also there isn’t any information about the expected state of DI for normal operation (NO/NC?). The documentation should also include descriptions of functions that can be set during application configuration. Some of them are not described at all and you do not know what they are used for. For example “Disable errors” (for pumps) od Settings screen. I don’t know which errors will be disabled and what is the current state. Does the button text indicate the current state, or what state this function switches to when the button is pressed? 2) Some errors in visualisation screens. Setting Pump 1 operation mode to “Hand” causes disappearance of the status box from the Overview screen:
Setting Pump 1 operation mode to “Hand” causes that both pumps in the Overview screen are shown as in “Hand” mode:
3) Actual hour and date are not stored after reboot. Also setting new date and time often requires the button to be pressed several times until it works. 4) Function “Pump change by switching operation mode” can not be enabled. Always only “Disable” button is highlighted. 5) What is the function of confirmation of notification?
After a power failure is triggered, the notification “General Error” and “Power supply” appears. When the error signal is cleared, the notifications automatically disappear.
In contrast, after a level error is triggered, the notification “General Error” and “Level sensor” appears, but after the error signal has been cleared, the notifications remain and cannot be deleted by clicking “Confirm” button. 6) SMS notifications. I realy don’t know how it works. In the settings screen I activated the modem and set the correct IP address and telephone number. In the Notifications screen I checked all “SMS aktiv” boxes. In the Overview screen Modem Eth Connectin state is “green”. TC Router 2702528 is also configured correctly. During all my tests, during which I triggered several dozen different alarm situations, I received only one text message about Power Supply Error. I received it yesterday and since then I have not been able to make another notification resulting in receiving an SMS.
